HyperWorksEngineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver
technology.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with
a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing
tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of
multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop
height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Free Body Diagram (FBD) utilities facilitate the extraction and post-processing of
grid point force results.
FBD extractions are typically utilized for breakout and/or sub-modeling analysis
schemes, where balanced "free body" sub-cases are extracted from a coarse grid model
and applied to a fine grid sub-model for eventual optimization and/or analysis. FBD
is also used to extract cross-sectional resultant forces and moments, typically at
the centroid of a cross-section, for use in traditional strength calculations.
Figure 1. Coarse Grid Model, Typical for FBD Extractions
Figure 2. Typical FBD – Forces Output on a Wing Rib
Figure 3. Typical Result Force and Moment Output on a Floor Beam
Review Load Collectors
Graphically review and manage the load collectors generated from all FBD and Resultant Force and Moment utilities.
Export Load Collectors
Export FBD, Displacement, and/or Resultant Force and Moment load collectors generated by other FBD utilities.
Review Grid Point Force Balance
The Grid Point Force Balance table is the data around which all FBD-Forces and Resultant Force and Moment utility calculations are performed.
FBD Solver Interfacing
The Free Body Diagram utilities behave differently depending on the solver that you interface with in HyperMesh.
