Thermal Effects Loadcase Tutorial
For the purpose of tutorial, you will make use of the solver deck (FEM) file from the first usecase, Risk and Root Cause (Dynamic) Analysis.
Multiple Loadcase Definition
Below are the steps to setup the Dynamic and Static loadcase setup for the tutorial model.
- Launch HyperWorks Desktop 2021
from installed location.
HyperWorks Desktop 2021 will open and user interface will be displayed as shown below.
Figure 1. - Click
- All the pre processing tasks will be loaded and displayed in the
SnRD-Pre tab.
Figure 3.
- Click
in the Model File field.
Browse and select
Tutorial_IP_SNR_Model.fem
from the Risk and Root Cause (Dynamic) Analysis model folder. - Select
dts_document.csv
andmaterialdb_sar.csv
from the tutorial files location for DTS File and Material Data File options. - Click
Apply.
An user message will be displayed for E-Line Pre-output CSV import option.
Figure 4.
- Click Import. A file browser window will appear. Browse
and select
Tutorial_IP_SNR_Model_pre_output.csv
from the Risk and Root Cause (Dynamic) Analysis model folder.This will import the Dynamic workflow solver deck into Static Loacase Setup
- Click Next to continue the process.
