Auto E-Line Creation Tutorial
This section of the document will walk you through the Auto E-Line Creation steps.
Control Panel Upper
andIP Substrate
Dashboard Panel
andIP Substrate
Auto creation of connectors for Tutorial
View new features for Engineering Solutions 2021.
HyperWorks Engineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver technology.
Discover Engineering Solutions functionality with interactive tutorials.
Noise, Vibration and Harshness (NVH) is an important vehicle attribute that directly affects the customer experience.
Use Squeak and Rattle Director tool to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
Details about the strengths of SnRD as a tool.
Use of Altair Ziegler SnR Material Database.
The process involved in SnRD workflows.
Below is the list of files required to complete the tutorial activity for the various usecases:
The workflows risk and analysis of squeak and rattle issues.
You will evaluate model for SnR issues for dynamic/transient loading condition.
You will evaluate SnR issues for static/touch point locations.
to evaluate SnR issues when system is imposed with multiple loading conditions,. I.e vehicle is parked under direct sunlight and is driven off.
to forecast the SnR issues in the systems based on the manufacturing variations like, component thickness, attachment stiffness, modal damping and etc.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Solver interfaces supported in Engineering Solutions.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
Setup an Optimization in Engineering Solutions.
Control Panel Upper
and IP Substrate
Dashboard Panel
and IP Substrate
From graphics area, select
Control Panel Upper
and IP Substrate
and click proceed
From graphics area, select the line present between the selected component and click proceed.
30
for Spacing and
Search Distance.
yellow
as shown below.Dashboard Panel
and IP
Substrate
