Create Local Mesh by Defining Size Use the Local tool to interactively create mesh on select surfaces by defining element size. From the Mesh ribbon, click the Local tool. Figure 1. Optional: On the guide bar, click to define surface mesh options. Select surfaces. Click Mesh on the guide bar or the microdialog. Surface mesh is created.
