Change the Mouse Controls
Change the mouse button and keystroke combinations used to rotate, pan, and zoom so they match other commonly used CAD applications.
  1. On the File menu, click the Preferences button.
  2. At the left of the Preferences window, under Category > Inspire, click Mouse Controls.
  3. At the right of the Preferences window, click Same As and choose an application. For example, click HyperWorks to use the same controls as HyperWorks.
  4. Click OK.
Tip: Inspire Form supports the 3Dconnexion peripherals. No additional setup is required, but the device needs to be connected to your computer before Inspire Form is launched.
