Flux-AMESim co-simulation: complementary
Calculus of losses
As to the calculus of the losses, Flux proposes the following two calculi:
| Type | Losses by Joule effect in … | Flux Sensor |
| Electrical circuit losses | the coils and the resistors of the electrical circuit | FLUX_LOSSES_COND_BOB + FLUX_LOSSES_RESISTANCE |
| Electromagnetic losses | the regions of solid conductor type – eddy current losses | FLUX_LOSSES_DOMAIN |
Supplementary parameters
Concerning the parameters management, it is possible to distinguish the input and output parameters, necessary for the proper operation of the
co-simulation and the supplementary parameters, respectively.
| Parameter | Management |
Input parameters (AMESIM_...) Output parameter (FLUX_...), |
automatic / invisible to the user |
| Supplementary parameter (PARAMETER …) | The user's responsibility |
Les paramètres supplémentaires sont des paramètres Flux dont les valeurs peuvent être transmises à AMESim.
These parameters are :
- geometric parameters (independent)
- I/O parameters type
Project F2A
While the coupling component is validated by the user (phase 1), the Flux software generates the new Flux project for the co-simulation (named F2A).
This project will be called by AMESim during the co-simulation. The management of the input parameters (amesim_...), of the output parameters (flux_...) and of the supplementary ones (parameter …) is invisible for the user.
The new project NAME_PROJECTF2A.FLU is characterized by:
name :
same name as the initial project with the suffix F2A
localization :
same folder as the initial project
File F2A
In the project F2A, Flux stores a data file of the coupling (AMESIM_LINACT.F2A or AMESIM_MOTOR.F2A).
This file is stored in the persistent folder.
It facilitates storage of the following data:
Version coupling component |
Flux information server version, numerical memory, character and HCI. A value of "0" corresponds to dynamic memory mode (MEMSIZN3 and MEMSIZC3). |
Input parameters (for Flux) |
Output parameters (for AMESim) |
Supplementary parameters (for AMESim) |
