Flux-AMESim co-simulation: linear actuator
Conditions of operation
The studied device is a linear actuator.
It is characterized by:
- a mobile part, with translating motion along an axis
- a magnetic circuit, in which eddy currents are developed
- a coil of the stranded conductor type, supplied from a voltage source
Description in Flux
The described device in Flux should observe the rules listed in the table below.
- Dimension: 2D plan, 2D axis, Skew or 3D
- Application: Magnetic Transient
- Physical:
| Mechanical |
A mobile mechanical set:
| Electrical |
A coil supplied by a voltage source:
- Solving: The solving scenario(s) in Flux will not be taken into account. It is the AMESim software that manages the time step of the simulation and imposes it to Flux during the co – simulation.
- No more than one mechanical set
- No more than one coil
- No more than one voltage source
Coupling component
To carry out a Flux-AMESim co-simulation, in Flux the user creates a coupling component (phase 1).
The coupling component facilitates the:
- setting of the conditions for data exchanges
- generation of the co-simulation Flux project (named F2A)
Conditions of exchange / linear actuator:
- name of the mechanical set in translating motion
- name of the voltage source
- choice for the calculus of losses:
- without losses / with losses
- losses in the electrical circuit
- electromagnetic losses
- addition of supplementary parameters
The coupling component is created when the project is ready for solving (physics completely described).
Exchange of data (1)
The exchange of data is carried out by means of the predefined parameters as presented in the diagram below.
Exchange of data (2)
The I/O parameters predefined in Flux during the creation of the coupling component are given in detail in the table below.
The input parameters (in Flux) are I/O parameters of the multiphysical type. Their value is piloted by AMESim.
| I/O parameters of multiphysical type | |
| AMESIM_VOLTAGE | Value of the voltage source voltage |
| AMESIM_POSITION | Linear position of the mobile mechanical set |
| AMESIM_TEMPERATURE | Operation temperature |
The output parameters (of Flux) are I/O parameters defined by means of formulas.
| I/O parameter of the formula type | ||
| FLUX_CURRENT | Current in the electrical circuit | I(NOM_SOURCE_TENSION) |
| FLUX_FORCE |
Electromagnetic force over the mobile part |
ForceElecMag(NOM_EM_MOBILE) |
| FLUX_LOSSES | Losses in the electrical circuit, respectively the Joule losses in the stranded coils and in the resistors of the electrical circuit | FLUX_LOSSES_COND_BOB + FLUX_LOSSES_RESISTANCE |
| Electromagnetic losses, respectively the Joule losses in the regions of solid conductor type, due to the eddy currents | FLUX_LOSSES_DOMAIN | |
