View Results
Results obtained from the remote cluster machine can be viewed in POSTFEKO on a local machine as if the simulation was run locally.
Use PREFEKO to perform meshing and to prepare the input files for the Feko solver.
Use PREFEKO with the correct syntax and optional parameters for advanced control.
The Solver is the electromagnetic solver component that calculates the specified output requests.
OPTFEKO is the component that controls the optimisation process. The optimisation parameters are usually associated with geometric dimensions, material properties, excitations and loadings. For example, the gain of a horn antenna is maximised by varying the size of the horn aperture.
ADAPTFEKO is the adaptive frequency utility used to automatically select smaller frequency steps near narrow resonances and larger steps where the results are relatively smooth.
The initfeko.bat (batch file on Windows) and initfeko (bash shell script on Unix / Linux) scripts are executed from a terminal to configure the Feko environment. From this environment, the Feko applications can be launched without using their full path.
The Launcher utility is a single application that allows you quick access to the shortcuts for the Feko components, WinProp components, newFASANT, documentation, Altair license utility and updating parallel credentials. Pin the application to the taskbar for quick launching.
The feko_update_gui utility and the feko_update utility allows you the flexibility to install an update containing features, minor software enhancements and bug fixes on top of an existing base installation for Feko (which includes WinProp and newFASANT).
In the event of a crash occurring in CADFEKO, POSTFEKO or EDITFEKO, the crash report utility generates a crash report.
QUEUEFEKO is a graphical user interface (GUI) application that can create a package which you can transport to a remote queuing system. Created packages can be extracted once the simulation on the queuing system has been completed.
The QUEUEFEKO graphical interface is used on the local machine to create the package that is then transferred to the compute cluster. On the compute cluster, use the queuefeko script to add a package to an execution queue.
The steps for creating and extracting a package for remote execution, are explained.
A package configuration file is not the package itself but includes the settings to create a package. The file can be reused to create packages with similar settings.
The .pre file is read to determine the required files to perform the simulation. Files that form part of the Feko project (but not required for the simulation) can be added manually.
For the remote cluster, you can specify the Solver options used.
For the remote cluster, you can specify the specific job queue that is to be used and set up email notifications when the job starts or completes.
Create the package that is to be added to the execution queue.
Transfer the package to the remote cluster where it is placed in an execution queue.
After the simulation has completed, a new output package (.output.pkg) is available for download from the remote cluster machine to the local machine. Extract the package using QUEUEFEKO.
Specify the PDF viewer used when opening the Feko documentation.
