Highlighting Specific Mesh Elements
The mesh highlight tool allows you to view areas of the mesh where specific model settings are applied.
![](../../bank/ribbon/../../../../images/feko/icons/button_highlight_none.png)
None
- No mesh elements are highlighted.
Lossy metal
- Highlight mesh elements (faces, wires) with a metallic medium and thickness applied to it.
Coating
- Highlight mesh elements (faces, wires, edges) with a coating (layered dielectric) applied to it.
CFIE / MFIE
- Highlight mesh elements (faces) with either a combined field integral equation (CFIE) or magnetic field integral equation (MFIE) applied to it.
EFIE
- Highlight mesh elements (faces) with the electric field integral equation (EFIE) applied to it.
Impedance sheet
- Highlight mesh elements (faces) with an impedance sheet applied to it.
Physical Optics
- Highlight mesh elements (faces) with the physical optics (PO) solution method applied to it.
Physical Optics (Fock regions)
- Highlight mesh elements (faces) with the physical optics (PO) solution method applied to a Fock region.
Ray Launching GO
- Highlight mesh elements (faces) with the ray launching geometrical optics (RL-GO) solution method applied to it.
Uniform Theory of Diffraction
- Highlight mesh elements (faces) with the uniform theory of diffraction (UTD) solution method applied to it.
FEM
- Highlight mesh elements (regions) with the finite element method (FEM) solution method applied to it.
VEP
- Highlight mesh elements (regions) with the volume equivalence principle (VEP) solution method applied to it.
Windscreen solution elements
- Highlight mesh elements (faces, wires) that are specified as windscreen solution elements (windscreen antenna elements).
Aperture
- Highlight a slot or aperture in an infinite plane with the planar Green's function aperture applied to it.
Numerical Green's Function
- Highlight mesh elements defined as the static part using the numerical Green's function.
![](../../../../images/feko/user_guide/postfeko/image_highlight_mesh_elements.png)
Figure 1. On the left, a 3D view of a horn and a reflector with no highlighting applied. To the right, the reflector is highlighted in yellow to indicate that PO solution method is applied to the face.
