Importing a Report Template for Reuse
A report template can be imported from an XML file to reuse in the current POSTFEKO session.
  1. On the Reporting tab, in the Reports group, click the  Import / Export template icon. From the drop-down list select the Import report template (*.xml) icon.
    Figure 1. The Import report template dialog.
  2. In the File name field, browse for the XML file to import.
  3. Click OK to import the XML file and to close the dialog.
