Computation Time and Peak Memory
Computation time and memory data consist of the computation time for the different stages of the solution such as checking the geometry and matrix calculation time. The peak memory and memory per process is also provided.
The final section in the output file gives an overview of the computation time, in seconds, in a
SUMMARY OF REQUIRED TIMES IN SECONDS CPU-time runtime Reading and constructing the geometry 0.184 0.184 Checking the geometry 0.095 0.095 Initialisation of the Green's function 0.000 0.000 Calcul. of coupling for PO/Fock 0.000 0.000 Transformation to equivalent sources 0.000 0.000 Ray launching/tracing phase of RL-GO 0.000 0.000 Calcul. of matrix elements 18.036 18.037 Calcul. of right-hand side vector 0.001 0.000 Preconditioning system of linear eqns. 0.437 0.439 Solution of the system of linear eqns. 3.367 3.365 Eigensolution for characteristic modes 0.000 0.000 Determination of surface currents 0.000 0.000 Calcul. of impedances/powers/losses 0.045 0.045 Calcul. of averaged SAR values 0.000 0.000 Calcul. of power receiving antenna 0.000 0.000 Calcul. of cable coupling 0.000 0.000 Calcul. of error estimates 0.000 0.000 Calcul. of electric near field 0.000 0.000 Calcul. of magnetic near field 0.000 0.000 Calcul. of far field 0.000 0.000 other 0.127 0.128 ------------ ------------ total times: 22.292 22.293 (total times in hours: 0.006 0.006)
Specified CPU-times are referring to the master process only Sum of the CPU-times of all processes: 89.173 seconds ( 0.025 hours) On average per process: 22.293 seconds ( 0.006 hours) Peak memory usage during the whole solution: 60.218 MByte (refers to the master process only) Sum of the peak memory of all processes: 233.845 MByte On average per process: 58.461 MByte
