Near Fields and SAR
Near fields and SAR data consist of values for the electric and magnetic field strength as well as specific absorbtion rate (SAR) data.
Electric Field Strength
The position as well as the individual components of the electric and the magnetic field strength are given. Unless otherwise requested in the request, the total value of the field, that is the sum of the incident wave and the scattered field, is given.
                        VALUES OF THE ELECTRIC FIELD STRENGTH in V/m
                           (total field, incident and scattered)
             LOCATION                              EX                   EY        ...
medium   X/m        Y/m          Z/m         magn.     phase      magn.     phase ...
 0  -1.00000E-01  0.0000E+00  1.25600E-01  2.0790E+01 -136.15  1.5550E+02   3.60  ...
 0  -8.87711E-02  0.0000E+00  1.25600E-01  2.1755E+01 -144.07  1.6368E+02  -5.91  ...
 0  -7.75422E-02  0.0000E+00  1.25600E-01  2.2504E+01 -150.94  1.6937E+02  -14.44 ...
                                                       EZ
                                                magn.     phase
                                             1.46636E+02 -155.96
                                             1.53094E+02 -165.59
                                             1.57508E+02 -174.30
Note: In the above table the spacing between columns was reduced to facilitate convenient rendering of line breaks in the rows of data.
The magnetic field strength data will have very similar contents.
Electric Fields inside Dielectric Cuboids
If the electric fields inside dielectric cuboids are requested (Electric field and SAR values request in the FE card) then the value for the SAR and the cuboid number are also given as follows:
                 inside the dielectric cuboids
   LOCATION           EX                EY                EZ           SAR  cuboid no.
 X/m    Y/m    Z/m     magn.   phase    magn.    phase    magn.    phase    in W/kg
 0.128  0.128  0.128 6.129E-01  -5.68  3.481E-04   -1.66 3.623E-02  87.60  0.0E+00   1
 0.128  0.128 -0.128 6.127E-01   4.80  3.479E-04   -0.42 3.622E-02  91.27  0.0E+00   2
 0.128  0.128  0.383 6.046E-01  -16.07 3.582E-04   16.84 3.651E-02  85.05  0.0E+00   3
 0.128  0.128 -0.383 6.042E-01   15.19 3.594E-04  -18.87 3.648E-02  93.84  0.0E+00   4
 0.128  0.128  0.637 5.851E-01  -26.50 2.032E-03  156.46 3.657E-02  79.21  0.0E+00   5
Note: In the above table the spacing between columns and the number of significant digits were reduced to facilitate convenient rendering of line breaks in the rows of data.
SAR
For specific SAR solution requests, the following output is shown (note that the extract shown below is representative for a spatial peak SAR calculation. The output for other options like volume average SAR calculations will differ.)
                              SPATIAL-PEAK SPECIFIC ABSORPTION RATE in W/kg
                                for 10.0 g tissue in the shape of a cube
   Search includes entire domain
   Maximum volume fraction of air allowed in a SAR averaging cube:  20.0 %
    cube centre                         cube edge      mass       AR    tissue content
  x in m        y in m      z in m      in m          in g       in W/kg      in %
 1.0255E-01  3.3344E-02  1.0833E-02  2.1728E-02   9.9082E+00  2.82865E+00    93.07
           orientation unit vectors of the SAR cube
            5.98050E-01   1.03718E-01  -7.94719E-01
            8.00460E-01  -2.78161E-02   5.98740E-01
            3.99940E-02  -9.94218E-01  -9.96574E-02
Note: In the above table the spacing between columns and the number of significant digits were reduced to facilitate convenient rendering of the data.
