Script
View the script used to configure a session and export a report that highlights the antenna properties of the model.
--[[ AUTOMATIC QUICK REPORT GENERATION FOR ANTENNA PATTERN ANALYSIS ============================================================== This script loads the specified model. It then creates various views and graphs that display the far field pattern. These views are then exported to a PDF report ]]-- modelName = {} modelName[1] = "Horn" modelName[2] = "Patch" -- Get user input through Forms form = pf.Form.New("Select model") comboBox = pf.FormComboBox.New("Model name", modelName) form:Add(comboBox) form:Run() index = comboBox.Index app = pf.GetApplication() app:NewProject() app:OpenFile(modelName[index]..".fek") selectedModel = app.Models[modelName[index]] selectedConfig1 = selectedModel.Configurations[1] ffData = selectedConfig1.FarFields[1] -- This is a handle on the far field data itself view3D = app.Views[1] ffPlot = view3D.Plots:Add(ffData) ffPlot.Label = "ff3D" ffPlot.Quantity.ValuesScaledToDB = true view3D_top = view3D:Duplicate() view3D_top:SetViewDirection(pf.Enums.ViewDirectionEnum.Top) view3D_right = view3D:Duplicate() view3D_right:SetViewDirection(pf.Enums.ViewDirectionEnum.Right) view3D_front = view3D:Duplicate() view3D_front:SetViewDirection(pf.Enums.ViewDirectionEnum.Front) polarGraph = app.PolarGraphs:Add() ffTracePhi_00 = polarGraph.Traces:Add(ffData) ffTracePhi_00.IndependentAxis = "Theta (wrapped)" ffTracePhi_00.Quantity.ValuesScaledToDB = true ffTracePhi_90 = polarGraph.Traces:Add(ffData) ffTracePhi_90.IndependentAxis = "Theta (wrapped)" ffTracePhi_90.Quantity.ValuesScaledToDB = true ffTracePhi_90:SetFixedAxisValue(ffTracePhi_90.FixedAxes[2],90,"deg") polarGraph:ZoomToExtents() polarGraph.Title.Text = "Gain" polarGraph.Legend.Position = pf.Enums.GraphLegendPositionEnum.OverlayTopRight polarGraph.BackColour = pf.Enums.ColourEnum.LightGrey polarGraph:Restore() quickReport = app:CreateQuickReport(modelName[index].."AntennaQuickReport", pf.Enums.ReportDocumentTypeEnum.PDF) quickReport.DocumentHeading = modelName[index]..[[ Antenna: Automated Quick Report]] quickReport:SetPageTitle(view3D.WindowTitle, "Isometric View") quickReport:SetPageTitle(view3D_top.WindowTitle, "Top View") quickReport:SetPageTitle(view3D_right.WindowTitle, "Right View") quickReport:SetPageTitle(view3D_front.WindowTitle, "Front View") quickReport:SetPageTitle(polarGraph.WindowTitle, "Theta Cuts") quickReport:Generate()
