Viewing the 3D Currents
Add a currents result to the 3D view by searching and navigating the documentation.
Multiple results from multiple requests can be added to the same 3D view. Therefore results are added to a collection.
Simple examples demonstrating antenna synthesis and analysis.
Simple examples demonstrating antenna placement.
Simple examples demonstrating radar cross section (RCS) calculations of objects.
Simple examples demonstrating electromagnetic compatibility (EMC) analysis and cable coupling.
Simple examples demonstrating using waveguides and microwave circuits.
Simple examples demonstrating phantom and tissue exposure analsysis.
A simple example demonstrating the time analysis of an incident plane wave on an obstacle.
Simple examples demonstrating using continuous frequency range, using the MLFMM for large models, using the LE-PO (large element physical optics) on subparts of the model and optimising the waveguide pin feed location.
Simple examples demonstrating using Feko application automation, matching circuit generation with Optenni Lab and optimising a bandpass filter with HyperStudy.
Use application automation to perform operations with CADFEKO and POSTFEKO. Typical tasks include repetitive tasks, tasks that require several steps, or calculations.
Learn the terminology of automation to create an automation script.
Learn to navigate the API documentation to find the correct syntax for an automation script.
Learn to navigate the API documentation to create a patch antenna using an automation script.
Post-process the results of a patch antenna on a multilayer substrate.
Create a new empty project in POSTFEKO.
Create a Cartesian graph by searching and navigating the documentation.
Add a far field trace by searching and navigating the documentation. Customize the trace quantities and font sizes.
View the completed POSTFEKO automation script.
Increase productivity when dealing with predictable and repeatable POSTFEKO sessions (for example, exporting a report) using application automation. Use an automation script to configure a session and export a report that highlights the antenna properties of the model.
Design matching antenna circuits with Optenni Lab and use the circuit in Feko.
Design a bandpass coupled line filter with HyperStudy as optimisation engine and Feko as the computational solver.
this_3Dview = app.Views[1]
When a 3D view is selected, the result palette shows a section entitled 3D View results.
my_3Dview_currents_plot = this_3Dview.Plots:Add(app.Models[1].Configurations[1].SurfaceCurrents[1])
my_3Dview_currents_plot.Quantity.ValuesScaledToDB = true
