Application Menu
The application menu is similar to a standard file menu of an application. It allows saving and loading of models, print functionality and gives access to application-wide settings.
When you click on the application menu drop-down button, the application menu, consisting of two panels, is displayed.
The first panel gives you access to application-wide settings, for example:
- Creating a new model.
- Open models, open a project, saving a project and closing a project.
- Import
- Export
- Check for updates
- Settings
- Preferences
- 3D mouse sensitivity setting
- Rendering options (for example, rendering mode and transparency mode)
- Component launch options
- Feko help
- About
- Version information about POSTFEKO
- Information about HyperWorks
- Information about third-party libraries
- Exit
The second panel consists of a recent file list and is replaced by a sub-menu when a menu item is selected.
![](../../../images/feko/bank/dialog_menu_application_postfeko.png)
Figure 1. The application menu in POSTFEKO.
