Feko Components and Workflow
View the typical workflow when working with the Feko components.
POSTFEKO
Create a new graph or 3D view and add results of the requested calculations on a graph or 3D view. Results from graphs can be exported to data files or images for reporting or external post-processing. Reports can be created that export all the images to a single document or a custom report can be created by configuring a report template.
After viewing the results, it is often required to modify the model again in CADFEKO and then repeat the process until the design is complete.
