Add Property Information
Provide archival information for a model including a description and creator name.
  1. From the ribbon, select the Model tool.
  2. From the Model dialog that opens, select the Properties tab.
  3. Enter a description and an author or creator name for your model. For lengthy descriptions, you can select the text editor, outlined in red in the following figure, and enter your information:
    The remaining fields on the tab are automatically populated as applicable.
