New to Activate? Learn the basics here.
Run Activate on Windows or Linux.
Discover new features and enhancements.
Operating system, hardware, software and memory requirements.
Define a variety of options for display, shortcuts, paths, and client behavior.
Run Activate on Windows in GUI mode or batch mode.
Run Activate on Linux in GUI mode or batch mode.
Learn how to access, annotate, display, select objects, navigate, add property information, and search in models.
The application workspace includes a combination of tools, browsers and palettes of predefined and programmable blocks to help you easily construct and simulate dynamical system models.
The workflow between the Activate client and engine facilitates the modeling of reactive systems.
Access help topics online or from your local installation.
Additional resources for Activate can be found on our learning center and forum websites.
Start using Activate with our interactive tutorials.
Learn about the components in Activate models.
Learn about modeling physical components.
Learn how to set up, run, and troubleshoot simulations.
Discover options to review, display, and export results.
Learn about block libraries for building dynamic system models.
Explore the Extended Definitions, OML Guides, Block Library, API Guide and Glossary.
Define shortcuts to common operations.
