Channel Impulse Response
The channel impulse response of the radio channel can be analyzed for each computed pixel within the simulation area.
Click Analysis > Channel Impulse Response or click the icon. You have the possibility to specify an evaluation location by positioning the mouse cursor in the result window. During mouse movement, the graph window is updated automatically. After clicking, the channel impulse response for the current location will be fixed.
Note: Channel impulse responses can only be analyzed if the simulation was calculated with a ray-optical propagation model and the additional ray data output was enabled. While loading the result file, you will be asked to load additionally available data. This question has to be answered with yes to do analysis of the radio channel.
Figure 1. Example of a channel impulse response for a specified location.
