Antenna Settings
ProMan allows also the assignment of time-variant behavior to an antenna. The antenna moves in the same way as the object group does to which the antenna is assigned, or moves as specified along the trajectory to which it is assigned. The trajectory can be edited at this stage.
Figure 1. Setting the location of the antenna as time-variant in the Cell dialog.
