Propagation
WinProp enables you to perform propagation studies for many applications, including but not limited to cellular mobile communication, WiFi, WLAN, vehicular communication systems, radio and TV, and communication with satellites.
Multiple transmitters can be placed. For each transmitter, quantities like frequency and power are defined by the user. For a quick look, the user can specify omnidirectional antennas, while for a more-sophisticated analysis an antenna pattern can be imported from an Feko simulation or from measured data.
Typical result quantities are maps of field strength and received power, rays between transmitter and points of interest, Line-of-Sight analysis results, and, depending on the simulation method, channel impulse response, delay spread and angular spread.
Scenarios include indoor, urban, combined urban/indoor, and rural / suburban.
