WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications
ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning
to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output
(MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine
the actual antenna pattern while taking into consideration the local environment.
WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models
as well as the unique dominant path model (DPM).
In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks,
ICNIRP and EM compliance.
In a straightforward way, you achieve the best of both worlds: the speed of an urban
simulation combined with the detail of an indoor simulation. A typical application is
cellular coverage inside a building of interest, while several other buildings of lesser
interest are in the vicinity, possibly partly obstructing the line of sight to the base
station. To specify the geometrical database, open an urban database in WallMan and
import an existing indoor database. After positioning the indoor database in the urban
one, you have a combined urban/indoor database. It has the same file extension as the
regular urban database, but ProMan will include the indoor detail in the simulation.
