Transmission / Penetrations Along Rays
The number of transmissions / penetrations are not limited in the rays considered for the computation. The transmission/penetration loss of an object intersecting any ray must be added to the free space loss LFS of this ray:
An object is defined as a planar polygon. The material properties of the objects can be defined individually.
The determination of the intersection between a ray and an object is explained with a simple example. If more objects must be considered, this analysis must be made for each object individually.
Figure 1. Intersection of ray and objects.
Consider the transmission of the ray between the two points P1 and P2. The point Q is computed as the intersection between the line represented by P1 and P2 and the object (described by the normal vector nW and its distance to the origin of the coordinate system). If nW is parallel to the direction from P1 to P2, no transmission / penetration is assumed.
Figure 2. Transmission/Penetration must be considered or can be neglected.
