Specifying the Output Folder for the Prediction Results
Specify the folder for the prediction results to be computed using the 3D ray tracing (SRT) model.
Launch the Edit Project Parameters dialog using one of the
following workflow:
- On the Project menu, click
Edit Project Parameters.
- On the Project toolbar, click the
Edit Project Parameters icon.
- Press F3 to use the keyboard shortcut.
- Click the Propagation tab.
Specify the output folder for the results to be computed using the 3D ray tracing (SRT) model.
- Under Output Directory / Basic Filename for Propagation Results, in the Directory field, change Prop01_MW to Prop01_SRT.
