Shadow Catcher
Create solid (not transparent or translucent) objects that cast and receive shadows.
![](../../../images/figures/studio/mat_shadow_catcher.png)
The cube is the shadow catcher object in this scene. As you can see, it casts and receives shadows. It also casts reflections, but does not receive them. A red anodized metal was applied to the plane, while no material has been applied to the sphere.
Main Parameters
- Reflectivity
- Define the strength of the reflections.
Enter a value of 0-100, where 100 produces perfect mirror reflections and 0 produces the weakest reflections.
- Roughness
- Roughness adds texture to the material at a microscopic level. When you
modify the roughness, the surface texture still looks the same; however,
tiny changes invisible to the naked eye have occurred, affecting
reflectivity.
To add a roughness map, upload an image.
0 can produce a perfect mirror reflection.
Lower values produce crisper and brighter reflections.
Higher values produce blurrier, dimmer reflections. Increasing the roughness spreads and distributes reflections over the surface and creates a more matte surface.
At values approaching 100, light becomes so scattered that reflections are barely visible, if at all.
