Save a Material to the Library
Save a custom material to the library so you can reuse it later.
If you modified a preset material in the Material Library or created a new Full material, you can save it to the material library.
If you are currently editing the material and the Material tool's Control Panel is open, you can follow the steps below. Otherwise, in the Model Browser, click the Materials tab, right-click the material name, and then click Save material.
  1. Enter a Material name.
  2. Click the Save to Library button.
  3. Define the Texture size, Package/Category, and Name.
