Inspire Render software is a 3D conceptual rendering environment which empowers designers to swiftly create and evolve photorealistic
visualizations of forms. Inspire Render software is one of the very few 3D design products which supports both Windows and Mac OS X systems.
The software saves versions of your objects as you create them, enabling you to return to an earlier stage of an object,
and modify or reuse the object from that stage.
Capture an image of a model. The background is white by default, but you can make it colored or transparent. Arrows
on curves are automatically turned off.
Inspire Render has three different tool belts to help you quickly access the tools you need to create highly realistic renderings.
You can use the tool belts with the default configuration of tools or you can customize the tool belts by adding and
removing tools as required.
What is Altair Inspire Render? Inspire Render software is a 3D conceptual rendering environment which empowers designers to swiftly create and evolve photorealistic visualizations of forms. Inspire Render software is one of the very few 3D design products which supports both Windows and Mac OS X systems.
Select and Edit
Review techniques for selecting and editing objects.
Construction History
The software saves versions of your objects as you create them, enabling you to return to an earlier stage of an object, and modify or reuse the object from that stage.
Adjust the View
Change the view in the modeling window using the mouse or view controls.
Take a Snapshot
Capture an image of a model. The background is white by default, but you can make it colored or transparent. Arrows on curves are automatically turned off.
Move and Snap
Translate, rotate, and scale objects using the Move tool. These tasks can be accomplished with greater precision by using grids and snaps.
Browse and Organize
Browse and organize the objects, layers, lights, materials, and drawings in your scene using the Model Browser.
Help and User Assistance
Learn about the forms of help and user assistance available from the product.
Tool Belts Inspire Render has three different tool belts to help you quickly access the tools you need to create highly realistic renderings. You can use the tool belts with the default configuration of tools or you can customize the tool belts by adding and removing tools as required.
Preferences
Modify the workspace display, default keyboard shortcuts, and other settings.
