Numeric Needle Graph (Standard & Horizontal) Settings
These are divided into four tabs:
General
Setting
Needle Width
Specifies the width in pixels of each needle.
NOTE: This is overridden when a column is added in the Size variable. Consequently, the width of the needles will be based on the comparison of their size in relation to where they are located on the X-axis.
Max Focus Radius
Determines the maximum radius of the focus circle when hovering on the needles.
This also controls the padding of the axis in the direction in which the needles expand, allowing the focus circle to have enough space to be drawn.
Show Border around Needles
Specifies whether a border is drawn around needles. These are only visible if the Needle Width is greater than 1 pixel.
Show Labels in Needles
Specifies whether node labels will be displayed.
Axes
Refer to Visualizations Axes and Cross Tab Axes for more information.
Synchronization
Filters
Refer to Visualization Static Filter for more information.
