Funnel Chart Settings
These are divided into four tabs:
General
Setting
Bar Thickness Ratio
Specifies the thickness ratio of the bars and spaces between bars.
Bar Width Padding
Specifies the width padding between the bar and the border.
Show Borders
Determines if a border is drawn around each bar.
Show Values on Bars
Determines if values are displayed in bars.
Axes
Refer to Visualizations Axes and Cross Tab Axes for more information.
Synchronization
Filters
Refer to Visualization Static Filter for more information.
