Dot Plot Settings
These are divided into four tabs:
General
Setting
Dot Radius
Specifies the radius of each dot in pixels.
Show Borders Around Dots
Determines whether a border is drawn around each dot.
Show Grid Lines Through Dots
Determines whether grid lines are drawn through each dot.
Show Lines Between Dots
Determines whether a line is drawn between the dots category constituents. Allows a categorical line graph to be displayed.
Line Width
Specifies the width in pixels of the line if enabled.
Axes
Refer to Visualizations Axes and Cross Tab Axes for more information.
Synchronization
Filters
Refer to Visualization Static Filter for more information.
