Selecting this option the user indicates the type of observation to be performed. If the Bistatic option is selected, the user must define the angle of incidence using the Source menu. In both cases, the output parameters must be specified using the Output menu.
![](../../../../images/newfasant/gtd_po/rcs_menu/menu_rcs.png)
Figure 1. RCS panel
