Radioss
Radioss
2021.2
  1. Home
  2. Reference Guide
  3. Engine Input
  4. Initial State
    Engine Keyword In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature, etc.) in state file (STA-File).
  5. /STATE/SHELL
    In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature…) for shell element in state file (STA-File).
  6. /STATE/SHELL/ORTHL
    Engine Keyword Describes the orthotropy direction for shell.
  • What's New
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Verification Problems
  • Frequently Asked Questions
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
Index
Radioss
2021.2
Radioss
  • What's New
    View new features for Radioss 2021.2.
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
    • File Extensions and Formats
      Radioss format 2021 uses the 12x extension format.
    • Single File Input
    • New Keywords in 2021
    • Starter Input
    • Engine Input
      • Engine Keywords Syntax
      • General Controls
        Engine Keyword In this group of keywords are used to generally define the output style, control of computation, damping and ALE setup during the computation.
      • Deletion/Input Modifications
        Engine Keyword In this group, keywords are used for modification (deletion or add options) in Engine.
      • Animation and Post-processing Output Files
        Generates animation files containing results according to the keywords specified. The keywords are specified in the topics within Animation and Post-processing Output Files.
      • Implicit Solution
        Engine Keyword In this group keywords are used for implicit solution. Different implicit solver methods (linear, nonlinear, buckling or quasi-static), different options to control the implicit computation, different implicit time step method and implicit output messages are introduced.
      • Kinematics and Loading
        Engine Keyword In this group, keywords are used to define the kinematic condition (constrain/release rotation or translation DOF) and initial condition (rotational/translational velocity).
      • Time Step
        Engine Keyword In this group, keywords are used to define different time step control (STOP, KILL, CST or DEL, etc.) for different entities (shell, brick, beam, airbag, interface, etc.) during the computation.
      • Initial State
        • /DYNAIN/DT
          Engine Keyword Define time output frequency and parts to be written to the state file.
        • /DYNAIN/SHELL/STRAIN/FULL
          Engine Keyword Describes the strain state for shell in LS-DYNA format.
        • /DYNAIN/SHELL/STRESS/FULL
          Engine Keyword Describes the stress state for shell in LS-DYNA format.
        • /STATE/BEAM/AUX
          Engine Keyword Describes the internal variable state for beam.
        • /STATE/BEAM/FULL
        • /STATE/BRICK
          In this group, keywords are used to output different info (like stress, strain, orthotropy direction, temperature…) for solid element in state file (STA-File).
        • /STATE/DT
        • /STATE/INIMAP1D/Keyword3
          Engine Keyword A state file is written with mapping data as functions (/FUNCT) or generated into a binary file.
        • /STATE/INIMAP2D/Keyword3
        • /STATE/NO_DEL
          Engine Keyword Writes the state file for only non-deleted elements.
        • /STATE/NODE/BCS
          Engine Keyword Boundary conditions for Node. The boundary conditions applied to nodes be written to the state file.
        • /STATE/NODE/TEMP
          Engine Keyword Describes the temperature for nodes.
        • /STATE/NODE/VEL
          Engine Keyword The velocity of a node is written to the state file.
        • /STATE/SHELL
          • /STATE/SHELL/AUX/FULL
            Engine Keyword Describes the internal variable state for shell.
          • /STATE/SHELL/EPSP/FULL
            Engine Keyword Describes the Epsilon plastic state for shell.
          • /STATE/SHELL/FAIL
            Engine Keyword Describes the failure criteria state for shell.
          • /STATE/SHELL/ORTHL
          • /STATE/SHELL/STRAIN/FULL
            Engine Keyword Describes the strain state for shell.
          • /STATE/SHELL/STRAIN/GLOBFULL
          • /STATE/SHELL/STRESS/FULL
            Engine Keyword Describes the stress state for shell.
          • /STATE/SHELL/STRESS/GLOBFULL
        • /STATE/SPRING/FULL
          Engine Keyword Describes the internal variable state for spring elements.
        • /STATE/STR_FILE
          Engine Keyword When writing the state file, /INISHE, /INISH3 and /INIBRI will be written in a separate file which can be asked for being compressed (using GZIP) or not. The state file will then resume to the nodes coordinates and element connectivity.
        • /STATE/TRUSS/FULL
          Engine Keyword Describes the internal variable state for truss.
      • Obsolete
        Engine Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
    • LS-DYNA Input (Beta)
      This manual contains an alphabetical list of LS-DYNA input files available in Radioss.
    • Optimization Keywords
    • Multi-Domain
      This manual contains the description of the Keywords for the Radioss Multi-Domain.
    • Other Files
    • Definitions
  • Example Guide
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
View All Altair Simulation Help
Radioss
Radioss
2021.2
  1. Home
  2. Reference Guide
  3. Engine Input
  4. Initial State
  5. /STATE/SHELL
  • What's New
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Theory Manual
  • User Subroutines
  • Starter Input
  • Engine Input
Index
/STATE/SHELL/ORTHL
/STATE/SHELL/ORTHL
  1. A block /INISHE/ORTH_LOC or /INISH3/ORTH_LOC or /INISHE/ORTH_LOC or /INISH3/ORTH_LOC is written into each state file, for each part declared into /STATE/DT.
