/INTER
Engine Keyword Describes an interface.
/INTER
inter_ID Nsearch Tstart Tstop
| Field | Contents | SI Unit Examples |
| inter_ID | Interface identifier. | |
| Nsearch | Search of closest node every Nsearch cycle. | |
| Tstart | Start time. | |
| Tstop | Stop time. |
- An interface can be activated and deactivated using Tstart and Tstop.
- If Nsearch is not used, any value can be set.
