/ANIM/GPS1
Engine Keyword Generates animation files containing simple average GPS data. The average value at node is calculated by the mean stress of all elements, which are connected to this node.
/ANIM/GPS1/Keyword3
| Keyword3 | GPS data type:
- /ANIM/GPS1 works only with constant stress element (8-node brick element with one point integration and TETRA4).
- The stress of the corner node is extrapolated from mean stress at integration point in all elements which are connected to this node.
