OS-SL-T: 1020 Fatigue Analysis of a Universal Joint
This tutorial demonstrates the creation of finite elements on a given CAD geometry of a universal joint.
The application of boundary conditions and a finite element analysis of the problem is explained. Post-processing tools are used to determine the fatigue life of the joint due to static loading.
- Set up the problem in SimLab
- Apply Loads and Boundary Conditions
- Solve the job
- View the results
Launch SimLab
Import the Model
Create Solution
Create Materials and Properties
Create Material
Create Property
Set Up Loads and Constraints
Define Torque Load
Define Constraints
Define Fatigue Solution
Solve and View Results
Solve the Solution
Interpret the Results
The results are automatically loaded in the modeling window.
Figure 12. Result Example
