Other Macros Toolbar
The Other Macros toolbar provides you quick access to the Calculate Angles, Find Connected Entities, Create Markers for Deformable Surface, and Contact Properties Editor macros.
Figure 1. Other Macros Toolbar
Left-click the corresponding button on the toolbar to display the window or panel for the selected item:
Calculate Angles Allows you to calculate spatial and planar angles between points.
Find Connected Entities Allows you to you to find entities which are connected to a selected entity (body, joint, or bushing).
Create Deformable Surfaces from FEM Allows you to quickly create a matrix of explicit markers to be used in defining a deformable surface.
Contact Properties Editor Allows you to edit the various contact forces applied to a model.
