Force Entity Toolbar
The Force Entity toolbar provides you quick access to the Forces, Modal Forces, Bushings, Fields, Spring Dampers, Beams, Polybeams, and Contacts panels.
Figure 1. Force Entity Toolbar
Left-click the corresponding button on the toolbar to set the filter for picking items in the graphics area to the currently selected entity/panel only, or right-click to display the Add "Entity" dialog (which is used to add entities to the current model):
Forces Allows you to create forces and to edit the orientation and properties of forces.
Modal Forces Allows you to include a distributed force on a flexible body that exists in the modal form in the flexible body H3D.
Bushings Allows you to edit the orientation, connectivity, stiffness, damping, and preloads of bushings.
Fields Allows you to create and edit fields to relate forces between two bodies.
Spring Dampers Allows you to edit the connectivity, properties, and initial conditions of springs and dampers.
Beams Allows you to edit the connectivity, properties, and orientations of beams.
Polybeams Allows you to edit the connectivity, properties, and points of a polybeam.
Contacts Allows you to set contact data.
