Create, organize and manage the CAE subsystem level models using any
entities.
Introduction
From the Assembly ribbon, click the satellite
icon on the Subsystems tool.
The browser opens in its own tab in the tab sidebar. You can
undock the browser so that it appears as a free-floating
dialog.
To create subsystems, you should use the Subsystem Browser with
the Model Browser and Part Browser open at
the same time.
Subsystem Browser Interface
The Subsystem Browser consists of two panes. The first displays
subsystems in the model along with attributes such as representations and revisions,
along with other entities contained in each subsystem. The second pane is the
Entity Editor. Figure 1.
Configure the Subsystem Browser
You can configure the Subsystem Browser in the following ways.
Add or remove columns in the browser by
right-clicking on a column heading then checking or unchecking the
appropriate attribute.
Sort by a particular entity by clicking on the heading of each column. For
fields that are alphanumeric, repeated clicks will toggle ascending or
descending order.
Filter columns by placing the cursor to the far right of the appropriate
column heading. A filter icon displays, which allows you to input the
filtering text.
By default, the following attributes are listed as columns:
Name
Expandable list of subsystems and entities.
ID
Identification number of the subsystem and entities.
Color
Color of the subsystem and entities.
UID
Subsystem and part unique ID.
Revision
The Major, Study, and Library revision of the subsystem and contained
parts.
Representation
In-session and loaded representation for the subsystem.
Active
Subsystem entity active status.
FE Style
Current FE style for components inside a subsystem.
