poISection SetThickness
Sets the thickness of the section cut edge lines.
poISection_handle SetThickness thickness
HyperView Tcl Modify
This command sets the thickness of the section cut edge lines. Only valid when running HyperWorks.
thickness
Thickness value from 1-6 or “global” to use the global section cut thickness as defined in the preferences.
Returns 0 if successful, otherwise an error code.
