poISection GetD
Gets the plane "D" parameter for a Planar section type.
poISection_handle GetD
HyperView Tcl Query
This command returns the plane "D" parameter for a Planar section type.
None.
View new features for HyperWorks Desktop 2021.2.
Gets the section base coordinate.
Gets the section base frame (for deformable sections only).
Gets the section base time.
Gets the current direction of the clipping surface (above or below).
Gets the boundary element clipping state for a section.
Gets the section cut color value.
Gets the state of color override option for a section cut.
Gets the cross section only state.
Gets the deform mode. Section cuts operate in either deformable or section_type (planar or spherical) mode.
Gets the state of the given section display option.
Gets the maximum plane "D" parameter for a Planar section type.
Gets the minimum plane "D" parameter for a Planar section type.
Gets the distance between each grid line on the local X axis for a Planar section type.
Gets the distance between each grid line on the local Y axis for a Planar section type.
Gets the precision of the grid text values for a Planar section type.
Gets the section ID.
Gets the section label.
Gets the section's orientation plane for a Planar section type.
Gets the section display mode, used to control polygon visibility for a Planar section type.
Gets the clipping sphere radius for a Spherical section type.
Gets the thickness of the section cut edge lines.
Gets the type of section.
Gets the section visibility state.
Gets the width of a cross section.
Reverses the current direction of the clipping plane.
Sets the section base coordinate.
Sets the section base frame (for deformable sections only).
Sets the base time for a section cut.
Toggles the current direction for the section.
Toggles the boundary element clipping state for a section.
Sets whether the clipped geometry (by iso or section cut) is displayed as transparent instead of being ignored.
Sets the section cut color.
Sets the state of the color override option for a section.
Sets the cross section only state.
Sets the plane "D" parameter for a Planar section type.
Toggles the deformable section mode.
Sets the amount to increment the plane's "D" when translating the section along the normal for a Planar section type.
Sets the state of the given section display option.
Sets the distance between each grid line on the local X axis for a Planar section type.
Sets the distance between each grid line on the local Y axis for a Planar section type.
Sets the precision of the grid text values for a Planar section type.
Sets the section label.
Sets the section's orientation plane for a Planar section type.
Sets the section orientation method for a Planar section type.
Sets the section's orientation plane by model/node ID pairs for a Planar section type.
Sets the clipping sphere radius for a Spherical section type.
Sets the thickness of the section cut edge lines.
Sets the section visibility.
Sets the width of a cross section for a Planar section type.
HyperView Tcl Query
None.
