poIPart SetRelativeTo
Sets positions relative to the parent assembly, local or global.
poIPart_handle SetRelativeTo id_string
HyperView Tcl Modify
This command sets positions relative to the parent assembly, local, or global.
id_string
Global, local, or a marker ID string that belongs to the same assembly as the part.
Returns 0 if successful, otherwise an error code.
