poIPart GetDefaultColor
Gets the part default color index.
poIPart_handle GetDefaultColor
HyperView Tcl Query
This command returns the part default color index. Generally, only the standard color commands should be used. The default color commands are used by the model reading code to control what was used as the default color (as opposed to the user set color).
None.
