poICrossSectionPlanar GetD
Gets the plane "D" parameter for a cross section.
poICrossSectionPlanar_handle GetD
HyperView Tcl Query
This command returns the plane "D" parameter for a cross section type.
None.
View new features for HyperWorks Desktop 2021.2.
Gets the cross section base coordinate.
Gets the cross section base frame (for deformable sections only).
Gets the cross section base time.
Gets the current direction of the clipping surface (above or below).
Gets the boundary element clipping state for a section.
Gets the cross section color value.
Gets the state of the color override option for a cross section.
Gets the component set information of the cross section.
Gets the display method of the cross section.
Gets the cross section only state.
Gets the deform mode.
Gets the state of the given section display option.
Gets the maximum plane "D" parameter.
Gets the minimum plane "D" parameter.
Gets the distance between each grid line on the local X axis for a cross section.
Gets the distance between each grid line on the local Y axis for a cross section.
Gets the precision of the grid text values for a cross section.
Gets the cross section ID.
Gets the IType value of the cross section.
Gets the ITypeID value of the cross section.
Gets the cross section label.
Gets the LENL value of the cross section.
Gets the LENM value of the cross section.
Gets the cross section's orientation.
Gets the cross section orientation method.
Gets the radius value of the cross section.
Gets the thickness of the cross section lines.
Gets the type of cross section.
Gets the cross section visibility state.
Gets the width of a cross section.
Gets the XHEV value of the cross section.
Gets the YHEV value of the cross section.
Gets the ZHEV value of the cross section.
Gets whether it is read only cross section or not.
Makes a cross section read only.
Reverses the current direction of the clipping plane.
Sets the cross section base coordinate.
Toggles the current direction for the cross section.
Toggles the boundary element clipping state for a cross section.
Sets whether the clipped geometry (by iso or section cut) is displayed as transparent instead of being ignored.
Sets the cross section color.
Sets the state of the color override option for a cross section.
Sets the component set information to the cross section.
Sets the display method to the cross section.
Sets the cross section only state.
Sets the state of the given section display option.
Sets the IType value to the cross section.
Sets the ITypeID value to the cross section.
Sets the cross section label.
Sets the LENL value to the cross section.
Sets the LENM value to the cross section.
Sets the cross section's orientation plane.
Sets the cross section orientation method.
Sets the radius value to the cross section.
Sets the thickness of the cross section lines.
Sets the cross section visibility.
Sets the width of a cross section.
Sets the XHEV value to the cross section.
Sets the YHEV value to the cross section.
HyperView Tcl Query
None.
