poICrossSectionPlanar GetClipAbove
Gets the current direction of the clipping surface (above or below).
poICrossSectionPlanar_handle GetClipAbove
HyperView Tcl Query
This command retrieves the current direction of the clipping surface. Returns "True" if the clip is above, or "False" if the clip is below.
None.
