hwIPage GetCurrentAnimationFramerate
Gets the current animation frame rate, in frames per second.
page_handle GetCurrentAnimationFramerate
HyperWorks Tcl Query
This command gets the current animation frame rate. This is the same value that is shown in the Frame Rate window that is visible when you click the Frame Rate button on the Animation Controls panel.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
hwi CloseStack
Error
This command should always return a floating point value.
