hwIPage GetActiveWindow
Returns the active window index.
hwIPage_handle GetActiveWindow
HyperWorks Tcl Query
Error
Success (0) or an error code.
View new features for HyperWorks Desktop 2021.2.
Adds a reference to an existing layer to the page.
Adds a window synchronization group.
Copies a window.
Forces each window to draw itself.
Indicates whether the active window on the page is expanded or not.
Returns the page animation mode.
Returns an animator object.
Gets the average animation framerate, in frames per second.
Returns the correlation difference for this page.
Gets the current animation frame rate, in frames per second.
Finds the default page layout.
Gets the page’s ID.
Gets whether a page is written out when running hwlSession_handle PublishSession.
Returns a list of layer ID's referenced by this page.
Returns the page layout type.
Gets the sync block ID of the master, if it is set.
Gets the model step state.
Returns the number of layers referenced by this page.
Returns the number of sync blocks associated with this page.
Returns the number of windows.
Gets the percent of maximum speed currently used by the animator.
Returns an animator object for a single sync block in the page.
Returns a list of the sync blocks on this page.
Gets the flag that indicates whether the animation is enabled for the sync block.
Gets the offset for the sync block identified by the sync block ID.
Gets the scale of the sync block identified by the sync block ID.
Gets the sync table generation policy.
Gets the animation sync tolerance for the page.
Returns the page title.
Returns the page title visibility flag.
Gets a handle to an hwIFont interface for the font of the page title.
Returns the window associated with the given window index.
Gets a list of the window IDs.
Gets a list of window IDs in the synchronization group.
Gets the current state of an existing window synchronization group.
Returns the current animator's animation state.
Combines windows.
Pastes a previously copied window.
Removes a window synchronization group.
Resets the average animation frame rate tracker.
Sets the active window.
Expands or reduces the active window on the page.
Enables the animation frame rate tracker.
Set the page’s animation mode.
Sets whether or not the page is exported.
Sets the page layout type.
Sets the new master sync block ID and recalculates the master sync table. This command is ignored if the sync table generation policy is not set to MASTER_BLOCK first.
Sets the model step state to on or off.
Sets the percent of maximum speed to be used by the animator.
Enables or disables animation for the model or page area containing the sync block ID identified.
Sets a new offset for the sync block identified by the sync block ID
Sets a new scale for the sync block identified by the sync block ID.
Sets the sync table generation policy.
Sets the animation sync tolerance for the page.
Sets the animation sync tolerance for the page in seconds and nanoseconds for better accuracy.
Sets the page title.
Sets whether or not the page title is displayed.
Changes the state of an existing window synchronization group.
Starts the animation.
Stops the animation.
Swaps the contents of two windows on a page.
