::SetState
This command will enable or disable the mdlSymCheckBox widget based on the input value.
::model::mdlSymCheckBox::SetState frmPath argState
MotionView Tcl
- frmPath
- This argument takes the path of the mdlSymCheckBox widget as input, which needs to be enabled or disabled.
- argState
- We need to pass either true or false to this argument to enable or disable the mdlSymCheckBox widget.
::model::GetClientHandle client
client GetModelHandle mod
mod InterpretEntity pbshandle PointMassBodyPair pb_0 "\"PointMassBody0\""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set sym_cb [::model::mdlSymCheckBox $colFrm.sym_cb pbshandle -items { "mass" }]
pack $sym_cb
::model::mdlSymCheckBox::SetState $sym_cb true
client ReleaseHandle
mod ReleaseHandle
pbshandle ReleaseHandle
On successful execution of the command, it will enable or disable the mdlSymCheckBox widget.
