::AddToolbarIcon
This command will create a new toolbar and add an icon to the toolbar.
::model::AddToolbarIcon toolbarname iconImagePath tcl_source_file [procname] [tip_text]
MotionView Tcl
This command will create a new toolbar in MotionView and will add an icon into it. The icon needs to be associated with a Tcl source file and optionally a procedure command within the source file. A tip text can also be optionally specified.
More than one icon can be added to a toolbar by using this command with the same toolbarname previously created.
Icons cannot be added to standard toolbars available in MotionView by default.
toolbarname
Name for the toolbar to which the icon will be added.
iconImagePath
File path location of the image file.
source_file
Tcl file that would be associated with the icon.
procname
Procedure name within the source_file to be called when the icon is clicked.
tip_text
Optional text for the tooltip.
::model::AddToolbarIcon “Custom Panels” “C:/Training/script/images/panel1.png” “C:/Training/script/mypanel.tcl” showPanel “Panel1”
# Adds a toolbar named “Custom Panels” with an icon.
Clicking the icon sources the tcl file mypanel.tcl and executes showPanel1 procedure within the tcl
::model::AddToolbarIcon “Custom Panels” “C:/Training/script/images/panel2.png” “C:/user/Training/script/mypanel.tcl” showPane2 “Panel2”
# This command when used subsequent to the above example would add another icon to “Custom Panels” toolbar.
None.
