::GetFirstCollector
This command will be used to get the address of the first collector within the mdlOrientation widget.
::model::mdlOrientation::GetFirstCollector argFrm
MotionView Tcl
- argFrm
- We need to pass the path of the mdlOrientation widget as the above argument, from which we need to get the address of the first collector.
::model::GetClientHandle client
client GetModelHandle mod
mod InterpretEntity mrk Marker mrk_0 "\"Marker 0\"" "" ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set ornt [::model::mdlOrientation $colFrm.ornt mrk]
pack $ornt
client ReleaseHandle
mod ReleaseHandle
mrk ReleaseHandle
tk_messageBox -message "First collector path: [::model::mdlOrientation::GetFirstCollector .test.tmpFrm1.ornt]"
On successful execution of the command, it will return the address of the first collector widget.
