::SetLabelText
This command will be used to create a label widget above the list collector widget.
::model::mdlListCollector::SetLabelText argFrm argText
MotionView Tcl
- argFrm
- We need to pass the path of the list collector in the above argument for which we need to create the label widget.
- argText
- This argument takes the text as an input for the label widget.
::model::GetClientHandle client
client GetModelHandle mod
mod InterpretEntity frchandle ActionReactionForce frc_0 "\"Force\"" "SC_ROT" "" "B_Ground" "" "POINT" ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set types "{POINT Point align_pt1} {VECTOR Vector align_vec1}"
set list_col [::model::mdlListCollector $colFrm.lcol frchandle "align_meth1" "$types" -references { POINT VECTOR }]
pack $list_col
client ReleaseHandle
mod ReleaseHandle
frchandle ReleaseHandle
::model::mdlListCollector::SetLabelText $list_col "NAME"
On successful execution of the command, a label widget will be created above the list collector.
